unconfigure identity-management
unconfigure identity-management {[[database memory-size] | [stale-entry aging-time] | [ports] | [kerberos snooping {aging time}]]}
Description
Sets the specified identity management configuration parameter to the default values.
Syntax Description
Sets the identity management database size to the default value.
Sets the stale-entry aging-time to the default value.
ports
Removes all ports from the identity management port list.
kerberos snooping aging time
Sets the kerberos snooping aging time to the default value (none).
Default
N/A.
Usage Guidelines
If no configuration parameters are specified, all configuration parameters are set to the default values.
The following command sets all identity management configuration parameters to the default values:
* Switch.4 # unconfigure identity-management
This command was first available in ExtremeXOS 12.4.
Platform Availability
